Houdini 16
   Views 141112   Replies 223   Subscribers 14
ndickson
stu
Any word on when the docs will be available?
The 16.0 docs are now available at both http://www.sidefx.com/docs/houdini/ [sidefx.com] and http://www.sidefx.com/docs/houdini16.0/ [sidefx.com]
Nope, still asking for Alpha/Beta permissions….
Houdini Indie
Karma/Redshift 3D
Daryl Dunlap
ndickson
stu
we've notice a few people having issues with the docs - they are being looked into right now.
Training Lead
www.sidefx.com
arctor
Daryl Dunlap
ndickson
stu
Hehe…maybe I was just too fast. All good now.
Houdini Indie
Karma/Redshift 3D
Yup, all good now.
First impression - Houdini 16 works quite slowly with high quantity of polygons. Is it common? How to fix it?
Moin,
eafreak
Hallo, I cannot seem to find the auto rig tools.
you can add a new pane and set that to type “Autorig”, see screenshot attached.
Marc
Good bye.
raistlinf
I did notice that turning off textured icon improves performance a LOT, and it was the main culprit of my performance issues.
raistlinf
Next daily build fixes it.
Martin Krol
raistlinf
Thank you Martin, it works.
Thank you Twod. I will be wait).
I use Linux. I Can't create a node in the network view : (invalid literal for float () : error in mouse event).
It works with the shelf…
But I'm happy to see H16
https://vimeo.com/user24950611 [vimeo.com]
The best thing in Houdini 16 is the radial menus! It turns Houdini into a whole new application!
How can I add HotKeys to the choices in the “Radial” menu?
For example:
How do I add the key “G” to switch to “Curve Modeling”?
How do I add the key “H” to switch to “Modeling”?
How do I add the key “I” to switch to “Poly Modeling”?
I didn't see how to do this in the Edit->Hotkeys… menu
Is this doable?
Thanks,
Marcus
The installer may have a few kinks in it. It rebooted my PC without prompting me and even though I checked uninstall 15.5 it didn't.
CreateTheImaginable
Oh it does ! Next stop, extend that workflow
nisachar
CreateTheImaginable
Agreed. Love these menus, now we just need to be able to customize them to our own workflows. I noticed the particles context is missing entirely from it unless I'm not seeing something obvious.
nisachar
nisachar
KunaniGaming
I noticed at the end it said 3D mous support. Does anyone have a list of compatible 3D mouse products? I was ready to pull the trigger on a 3Dconnexion SpaceMouse but want to make sure it will work with 16 properly.
I have one but I might be able to tell you after Feb 21st when they release the app.
I'm sitting here with my SpacePilot and it's not working with H16 Apprentice? Is it just a matter of having Indie or higher? Or is there a configuration profile I need to download etc?
Any pointers to getting my SP working are appreciated!
-Will
WillBellJr
-Will
Hello, It is working out of the box for me on my rMBP + Houdini Indie. I suppose Apprentice shouldn't be any diff.
The connexion shows Houdini Indie in the list of apps ( I don't remember adding it myself when I was using 15.5 ). Did you try adding Houdini manually ?
Oh man those booleans !!! <3
nisachar
WillBellJr
-Will
Noap, no joy, I just went and downloaded the latest drivers, again I have a SpacePilot Pro.
Looking at their supported packages, no mention of Houdini
http://www.3dconnexion.com/supported-software/software0.html [3dconnexion.com]
Sigh…
-Will
WillBellJr
nisachar
WillBellJr
-Will
Sigh…
-Will
I have the SpaceNavigator NB for notebooks ( http://www.3dconnexion.com/products/spacemouse/spacenavigator-for-notebooks.html [3dconnexion.com] ) and it is working on my 2013 MacBook Pro running MacOS Sienna 10.12.3! :-)
3DxWare10 ( version 10.4.3 )
SpaceNavigator NB ( Firmware 4.31 )
WillBellJr
I meant in the settings of the app.
