I'm trying to set a channel reference by entering a string in a set operation:
transformnode = hou.node('obj/track').createNode('xform', “transform” + str(minmaxspeedindexpoint))
transformnode.parm('px').set('ch(“../font' + str(x) + ‘/tx”)’)
but it's complaining that I can't set a numerical value to a non-numerical value.
how to set a channel reference in a Python script?
3322 3 1- dgirard
- 47 posts
- malbrecht
- 806 posts
Moin,
what's “x”? If it is undefined, it's definitely a non-numerical value (note that you are escaping from your quote in the parm().set() sequence, probably intentionally so).
One way to debug something like this is to set variables you use manually in a python shell (Houdini offers that conveniently) and step by step recreating the expression until you get the error. Then the last step/change you made is the culprit.
Marc
Marc
Good bye.
Good bye.
- 8836 posts
you nees to use .setExpression() instead of .set()
you can also use string formatting to build your strings
or the old string formatting, not sure whether that's being phased out or not, but for now may be shorter sometimes
transformnode = hou.node('obj/track').createNode('xform', "transform" + str(minmaxspeedindexpoint)) transformnode.parm('px').setExpression('ch("../font' + str(x) + '/tx")')
transformnode = hou.node('obj/track').createNode('xform', "transform{}".format(minmaxspeedindexpoint)) transformnode.parm('px').setExpression('ch("../font{}/tx")'.format(x))
transformnode = hou.node('obj/track').createNode('xform', "transform%d" % minmaxspeedindexpoint) transformnode.parm('px').setExpression('ch("../font%d/tx")' % x)
Edited by tamte - April 4, 2020 18:58:56
- dgirard
- 47 posts
