Laggy UI?
   16767   43   5
Hi, Arvin,
both DVR should not be “running”. If you haven't disabled MS' game recorder, you can do that from the XBox app (in Win10 that is). NVidia's recorder can be set to “custom”, so that you have to activate it by a (user-definable) keyboard shortcut.
Marc
Good bye.
Arvin Villapando
Hi guys - pinging this again. Sorry I contacted support but they can't seem to recreate the bug.
They suggested trying to guess and check on processes that may be doing it, but nothing.
Mathef - could you please try downloading OBS and screen capturing. For some reason if I wait about 5 sec. after I start recording, Houdini's issues go away. I thought this might have something to do with OBS forcing Windows to turn off certain display effects so I tried manually turning effects off, but no results there either. But yes - please check to see if this will work and maybe it can help pin point the bug.
Thanks for the suggestion Arvin, OBS didn't help. But after many reinstalls of Nvidia drivers and install of daily build 16.0.573_qt4 problem is gone. Even in qT5 version is everything ok. Can't explain what exactly helped unfortunately. I also tried unninstall the new nVidia thing - Vulkan drivers, but I dont think it was core of problem. But who knows
Edited by Mathef - April 13, 2017 12:15:44
Okay so after a few months I finally hit a point of needing to use Houdini for some real testing so I went back to trying to solve this problem. And thankfully it worked. For me in particular the solution was disabling the process called Touch Keyboard and Handwriting Panel Service.
For future problems what I had to do was literally start shutting off every service one by one. I did this before but didn't shut off what looked like crucial windows services. But today I tried going down line by line to shut each one down and found the culprit was in fact a Windows service. Hope this helps anyone who runs into this issue in the future.
In my case, having G-Sync enabled for Windowed mode in NVIDIA Control Panel causes the issue.
