Houdini on windows 7
Hello, Anyone out there who is using Houdini on Windows 7 (32 – bit Operating System)
hell im not able to install on Windows 7 :x :x :x :x :x :x :x
26642 17 2- conjuror
- 26 posts
- Helenerg
- 55 posts
- rafal
- 1455 posts
- splitpoint
- 57 posts
- ragupasta
- 349 posts
- jason_iversen
- 12676 posts
32-bit Win 7 at home (with Nvidia GTX 8800)… works fine – much better than 32-bit vista! I can finally run fluid-sims at home again!
- conjuror
- 26 posts
- conjuror
- 26 posts
- conjuror
- 26 posts
So pathetic………….. no fix for Houdini on Windows 7…………………. Hell what is gfont.exe…. why Houdini stops installation on particular position…………. Feel to through my laptop, sadly I can’t.. just about to finish emi. :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x :x
__________________
….Good Thoughts….
….Good Words……..
….Good Deeds……..
__________________
….Good Thoughts….
….Good Words……..
….Good Deeds……..
__________________
- goldleaf
- 4201 posts
- edward
- 7903 posts
conjuror
If you searched for “gfont” in this forum, you might have found this thread:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=11037 [sidefx.com]
I'd try what rafal said in that thread:
rafal
One possibility is that the installer encountered a bad truetype font.
Unfortunately, this happens from time to time due to the inherent nature of the
truetype font format. This installation step isn't necessary if you do not need
to use truetype fonts in Houdini and it can be rerun later if needed. So on
your system, first try to get Houdini installed without this step. Just kill
gfont.exe from the Task Manager.
Once Houdini is installed, we can debug the issue as follows:
1. Launch Command Line Tools from the Start Menu under
Side Effects Software > Houdini X.X.XXX.
2. Run this command: gfont -Sv This will generate verbose processing.
If the program stalls at any given point in time for longer than a minute, then
that is probably a bad font. If you send us that font file, then we can try to
fix gfont so that it can handle it.
- Ultravizn
- 18 posts
- Ignacio
- 12 posts
- conjuror
- 26 posts
I tried this but when ever I start Houdini it just don’t show any UI or not even in taskbar ha but shows in the services
edwardconjuror
I'd try what rafal said in that thread:rafal
__________________
….Good Thoughts….
….Good Words……..
….Good Deeds……..
__________________
….Good Thoughts….
….Good Words……..
….Good Deeds……..
__________________
- logon
- 6 posts
The lastest version of Catalyst display driver (9.4) just do the trick !
Worked for me on a laptop using mobility radeon HD3470. Everything’s just fine, Blender too !
Good Luck !!!
________________
Download Windows 7 [microsoftoffice-2010.com] | Download Microsoft 2010 [microsoftoffice-2010.com]
Good Luck !!!
________________
- JOEMI
- 128 posts
- Deadletter
- 5 posts
- vm
