When I switch to the channel editor to view CHOPs data, I do not see any lines. I loaded CHOP geometry node example file, and still no luck. I tried looking at all the settings, and restoring to defaults, but nothing has worked.
Please, help me see this important data!
win32
9.0.794
can not see data in the channel editor
18848 25 3-
- danmeyer
- 42 posts
- digitallysane
- 1192 posts
- danmeyer
- 42 posts
- andrewlowell
- 539 posts
- digitallysane
- 1192 posts
- symek
- 1390 posts
- andrewlowell
- 539 posts
Maybe, but it is used extensively for motion editing (or at least I use it for that, as well as audio)
If they really wanted to irk beginners they could just call it sample-graph (chops) and vector-graph (channel editor). Beginners wouldn't know where to animate, at all
For what it's worth, I guess the other names are more exciting (also less accurate)
OK, I'll see what I can come up with tonight with the video walkthrough I need a break from typing
- andrewlowell
- 539 posts
A little off-topic but is there an actual button for set-key anywhere, that threw me for a loop with H9 coming from a max background (because there is a button with a key on it but it doesn't set keys). I don't like to forceably memorize shortcuts even if I can set them to what I want.
hmmm, looking through help, doesn't look like it
- symek
- 1390 posts
- andrewlowell
- 539 posts
yes I knew about the “K” shortcut, and it's customizable. My point is that I'm being forced to use a shortcut for the set-key. I would like button to click on, it's a more finalizing feeling for me
o well.
I'm such a huge flake I promise I will do the CHOPs video walkthrough tomorrow (it's 3:30 am, I am behind schedule)
- symek
- 1390 posts
- danmeyer
- 42 posts
- mrCatfish
- 737 posts
- MichaelC
- 344 posts
andrewlowell
yes I knew about the “K” shortcut, and it's customizable. My point is that I'm being forced to use a shortcut for the set-key. I would like button to click on, it's a more finalizing feeling for meo well.
Right click on your shelf and select new tool, name it whatever you want and give it some icon. In the scirpt tab set the language to hscript and enter this command:
chcommit -s
Accept changes, you now have a button that will set keys on scoped channels in the channel editor.
- andrewlowell
- 539 posts
- andrewlowell
- 539 posts
Here we are!
man those things take forever to encode
http://www.andrew-lowell-productions.com/andrew-lowell-productions/TEMP_HVideoTuts/chops_intro_alowell.mov [andrew-lowell-productions.com]
Project files attached
- labuzz
- 82 posts
- Rafal.M
- 58 posts
- andrewlowell
- 539 posts
- digitallysane
- 1192 posts
Thanks for the tut, Andrew. It's very nice and useful. If exposed, it will help newcomers.
Unfortunately, this doesn't change one inch the fact that name “Motion View” is simply bad design, unintuitive and confusing. I find extremely saddening that users have to made tutorials with the purpose of helping newcomers deal easier with the bad design of a product.
Dragos
Dragos
