When adjusting an object in the view port using the move/rotate/scale handles the objects parameter's don't update in the ‘parameter pane’ while adjusting them, only once the adjustment is complete?
Is there a setting somewhere to enable the parameters to change whilst i'm using the objects handles?
Thanks,
Nic
Parameter update when moving/rotating object etc..
4020 3 0- niczoom
- 15 posts
- graham
- 1908 posts
- niczoom
- 15 posts
- sch1
- 13 posts
With the “Interactive Update” off, if I put down a node during playback, its parameters are not updated (–). When I stop the playback, I would expect the parameters to be updated. But they are blank, until I start changing them or click on the label, individually. And let's say I click on the label of one of the parameters so the value shows up, then create another node of the same type. The only parameter with values would be the one I just clicked in the old node, with everything else blank. Is this how it should work? Again, I would have expected an update to fill in the values of the parameters when the playback has stopped. This is houdini running on Linux, but I've seen it on a different platform as well.
Chyuan
Chyuan
