HDK: compile problem on mac
   Views 6662   Replies 6   Subscribers 3
Does anyone know another way to compile hdk code on the mac, since H10.0.blah hcustom has stopped working and now when I use it I get the following error
cc1plus: warning: command line option “-fobjc-gc-only” is valid for ObjC/ObjC++ but not for C++
Is there a way to modify hcustom or roll my own somehow?
It's working for me. I see that error but it's only a warning and the compile still works.
-Drew
That's really weird then. i can compile in H9.5 still but in H10 I get that error and then nothing else. Maybe it does compile, I'll have to check that, but if there are errors I don't get any messages about them which is not so useful.
Ah, yes it does compile, well that's something anyway. I can debug in H9.5 and compile for H10. Not sure how long that's going to work though but it will do for now.
I found “-d” very useful to diagnose compiler startup string and to setup my building environment manually to compile plugins. Hope it will help a little
Anything that flies
hey
I tried touching the SOP_Star.C and noticed that I didnt have permission to write into that folder, after logging into as a SU, it worked.
can any one else confirm this ?
One should NOT compile in the installation directory. Copy the sample files into your home directory somewhere and compile from there.
Hmmm…. I can't get it to compile either. I get hundreds of lines of errors, like all of the ones below except the bottom 3 lines:
/Library/Frameworks/Houdini.framework/Versions/10.0.461/Resources/toolkit/include/UT/UT_ErrorManager.h:133: error: initializer expression list treated as compound expression
/Library/Frameworks/Houdini.framework/Versions/10.0.461/Resources/toolkit/include/GU/GU_Detail.h:1153: error: ‘ostream’ has not been declared
/Library/Frameworks/Houdini.framework/Versions/10.0.461/Resources/toolkit/include/GU/GU_Detail.h:1154: error: ‘int64’ does not name a type
/Library/Frameworks/Houdini.framework/Versions/10.0.461/Resources/toolkit/include/GU/GU_Detail.h:1252: error: ‘ostream’ has not been declared
/Library/Frameworks/Houdini.framework/Versions/10.0.461/Resources/toolkit/include/GU/GU_Detail.h:932: error: ‘NULL’ was not declared in this scope
geoisosurface.C: In function ‘int main(int, char**)’:
geoisosurface.C:54: error: ‘NULL’ was not declared in this scope
Compile failed
Does this look familiar to anyone?
I'm o.d.d.
