I've found a script in Craig Zerouni - Houdini on the spot
On page 38 - Switching Around errors
Change input if other object has same error
Expression in the switch SOP
if (strmatch(“*Error:*”,run(“opinfo ” + opfullpath(“../” + opinput (“.”, 1)))),0, 1)
Expression is working,and it switches node on error, but on output of switch node nothing happens.
I can clearly see that select input value of the switch node changes from 1-0 but i cannot see that in the viewport.It always displays the first input.
It only works the first time when you edit the script..
even if you put eval to force the script to execute
its still the same thing
Problem with switch node...
8784 3 1- CeeGee
- 217 posts
- Dean_19
- 319 posts
Try this:-
if (strmatch(“*Error:*”,run(“opinfo ” + opfullpath(“../” + opinput (“.”, 1))))+$F-$F,0, 1)
I've had the same problem. I think I also attempted to use eval to try and force the recook/update. I think adding ‘+$F-$F’ to the expression did the trick in the end to force Houdini to ‘refresh itself’.
Dean.
Dean.
- CeeGee
- 217 posts
- vanyfilatov
- 16 posts
