Hi, I just downloaded the free houdini apprentice program and when I start up the program all the icons in the various toolbars are non-existant. From what I can see from online tutorial videos, the icons should be there. I am VERY new to the program and wanted some advice on how to fix this.
No icons in Houdini
27901 23 6-
- PixarRox
- 3 posts
- edward
- 7952 posts
- PixarRox
- 3 posts
- edward
- 7952 posts
- PixarRox
- 3 posts
- edward
- 7952 posts
From the Support menu above, go to Download. Look for the 10.0.492 build (or some build later). Download and try installing that one. Make sure you're logged into the forum first.
Only if that doesn't work, then try this video: http://www.youtube.com/watch?v=v8O3KIPOoWk [youtube.com]
- chadrik
- 9 posts
i'm also not getting any icons on osx 10.6.2. i've tried with builds 10.0.465 and 10.0.501. i've also looked at the YouTube video, which is basically a really complicated way of saying ‘sudo chmod -R 777 /Applications/Houdini*’. the latter fix seems to be targeted toward startup instability, which i am not experiencing. any further thoughts on how to fix this issue?
forgot to mention, this is 64bit, but i think that's the only option for osx.
- edward
- 7952 posts
- chadrik
- 9 posts
- edward
- 7952 posts
- jiwasa
- 2 posts
- MikeTaylor
- 154 posts
jiwasa
I just installed Houdini 10.0.514 (apprentice), and still can't see any icons. Deleting my Houdini preferences directory didn't seem to help.
I'm using Mac OS X 10.5.8.
Advice?
Do you have X11 installed on your Mac? Our utility that converts icons from SVG to PNG has a dependency on X11. We hope to remove that dependency in the future.
- jiwasa
- 2 posts
- dallin.pro@gmail.com
- 2 posts
- oat
- 479 posts
Dear all,
I think Mike Taylor and others have post a solution for this problem:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&p=82782#82782 [sidefx.com]
I'm gonna check this solution tmr and hope it works.
- bluedonkey
- 2 posts
This has been driving me nuts as well until now!
I run a MBP with Leopard 10.5.8 which I updated from earlier versions of tiger. I found out that this version of Leopard broke x11. If you install the latest update of x11
from here
http://xquartz.macosforge.org/trac/wiki/X112.4.0 [xquartz.macosforge.org]
Houdini works ! I am ecstatic.
from here
- 2 posts
- Andrew Graham
- 151 posts
hey guys, this is my first post on the apprentice forum.
i have installed the x11 update and am running os x 10.5.8.
i still can't get houdini 10.0.465 to work. all the icons have dissapeared.
https://openfirehawk.com/ [openfirehawk.com]
Support Open Firehawk - An open source cloud rendering project for Houdini on Patreon.
This project's goal is to provide an open source framework for cloud computing for heavy FX based workflows and allows end users to pay the lowest possible price for cloud resources.
- MikeTaylor
- 154 posts
queglay
We were having some installer permissions problems at that time. You should try downloading the 10.0 daily build from here:
http://www.sidefx.com/index.php?option=com_download&Itemid=208 [sidefx.com]
Before you install that, try fixing the permissions on your prefs dir (replace <username> with your username:
sudo chown -R <username>:staff ~/Library/Preferences/houdini
- Andrew Graham
- 151 posts
how do i enter that code? sorry im pretty new to macs.
