Why this happening ?
And
How to solve it ?
or
How I should generate this bevel in this case ?
thanks!
J.
extrude,poly extrude,poly bevel.
Bad side effect after bevel
4000 3 0- James_Burg
- 153 posts
- neil_math_comp
- 1743 posts
What “this” are you referring to? Do you mean the unusual shading? If so, does it look that way in the Rendering tab, or just in the viewport? If it looks the same in the Rendering tab, there's probably something off about the geometry or normals. You can recompute normals with a Facet SOP if that's the case. If it only looks that way in the viewport, I wouldn't worry too much about it, since your final renders will be fine, though applying a Divide SOP with convexing and max edges set to 3 (triangulating the geometry) might make a difference.
- mark
- 2597 posts
James_Burg
And
How to solve it ?
or
thanks!
J.
Likely, you have the face shared with the extruded sides. This is causing normals from the side edges to be shared with the face. If you use the facet SOP to “cusp” sides, this should improve your geometry… Or just unique points between the face and the edges another way.
- James_Burg
- 153 posts
