I've just installed ubuntu 13.10 (never used linux before) and Houdini 13.
I'm trying to make the alt button preform like the space bar for viewport navigation. I have found the check box under the main preferences and checked “Use Alt key for view controls”
I've installed Unity tweak tools and disabled “Invoke HUD” allocated to the alt key.
Under system settings I cant find any keyboard shortcuts assigned to the alt key.
What do I have to do in Unbuntu to stop it from calling the alt button when in Houdini?
Cheers
ubuntu 13.10 Config Alt button for viewport
4263 3 2- AlexLombardi
- 30 posts
- AlexLombardi
- 30 posts
Fount it
http://askubuntu.com/questions/67518/how-to-disable-window-move-with-alt-left-mouse-button [askubuntu.com]
I had to install ComplizConfig settings manager and disable initiate Window Move
- Sadjad Rabiee
- 1391 posts
If you wanna just change Alt key Behavior (Swap Win and Alt key) like windows , So you can change this Options :
Setting->Regional and Settings ->Layouts -> Options -> Alt/Win Key Behavior and select “Left Alt is Swapped with Left Win”
Of course I working with Mint now ,but I remember we have same option in the Ubuntu too.
I need to change this option for Maya and Houdini (Because Alt and Win key in the Ubuntu/Mint is swapped with Windows !)
- gangland
- 3 posts
Sadjad Rabieecant find this location, can you help me. i on mint
Setting->Regional and Settings ->Layouts -> Options -> Alt/Win Key Behavior and select "Left Alt is Swapped with Left Win"
