How to get paths, in /obj/ level, to all parent nodes, in separate strings, with Hscript?
May be not for all. For first 10 is enough.
I knows about`opinputpath(“.”, 0)`, but its working with inputs. not with parents
Maybe this picture explain what i mean
How to get paths to all parent nodes
9561 4 3- vanyfilatov
- 16 posts
- bollili
- 205 posts
I would do it in python.
Get the parent (and the parent's parent…) by refeeding the resulted parent node path into the next loop iteration until the result equals “/” (= root level).
Just append each result to a list and voilá.
If you just want the first 10 parents, you can add another break condition by counting the number of iterations.
- Dennis Weil
- 150 posts
I put a quick file together. There's a callback script on the button which executes the script from the multiline parameter. Would be cleaner to do it with a proper HDA though.
Does someone know a better way to execute python code from a string parameter? Or a way to inject this code into another python in the hda module so I can customize certain functionality without touching my DA? Similar to the way VEXpressions work.
- vanyfilatov
- 16 posts
- pezetko
- 387 posts
dennis.albus
You can use python modules for that.
E.g. create my_module.py in custom location and put all your code into it within functions.
#my_module.py
import hou
def test():
print(hou.pwd())
print(“Testing finished”)
def findFirstParents():
#node = hou.node(“.”)
node = hou.pwd()
start = node
node_list =
while len(start.inputs()) > 0:
input = start.inputs()
node_list.append(input.path())
start = input
node.parm(“pathmulti”).set(len(node_list))
for i, path in enumerate(node_list):
node.parm(“path”+str(i+1)).set(path)
print(node_list) #for debug
return True
Then inside houdini just import it and call your functions.
# import your custom module
import imp
my_module = imp.load_source('my_module', ‘c:\Users\petr\my_module\my_module.py’)
# calling function from this module
my_module.test()
my_module.findFirstParents()
You can edit your functions independently from your HDA or even from Houdini application. So no risk of loosing your code or have couple of different versions in different locations and assets, all is in sync.
I'm using that imp.load_source() all the time.
