Post your favourite Wrangle SOP presets
   107883   38   30
Everyone has set up their own set of Wrangle code presets. It would be useful if we shared some of our favourites here both for learning and speeding up work. Maybe SESI would add some of these to H14 for everyone.
I will get the ball rolling:
Group by Neighbour Count
if ( neighbourcount ( 0, @ptnum ) == chi("count") )
    setpointgroup ( geoself ( ), chs("name"), @ptnum, 1, "set" );
Parameters:
int count (Neighbour Count)
string name (Group Name)
Edited by animatrix_ - Dec. 10, 2023 07:22:06
Please do! We are always looking at adding good presets to the wranglers.
Thanks Jeff I am sure people have a lot better ones, but here's another one I use that works for any element (point, prim, vertex):
Color Random
float seed = 0.99 + ch("seed");
float r = hscript_rand ( @ptnum + seed + sin ( 13 * @ptnum + 19 * seed ) );
float s = fit ( random ( 17 * @ptnum + 91 * seed ), 0, 1, ch("srangex"), ch("srangey"));
s = ch("s") * ( 1 - ch("srand") ) + s * ch("srand") * ch("s");
float val = fit ( random ( 173 * @ptnum + 11 * seed ), 0, 1, ch("vrangex"), ch("vrangey"));
val = ch("v") * ( 1 - ch("vrand") ) + val * ch("vrand") * ch("v");
@Cd = hsvtorgb ( ( r + 0.618033988749895 ) % 1, s, val );
Edited by animatrix_ - Dec. 10, 2023 07:22:42
Creates a point in the center of each primitive.
This is for AttribWrangle SOP, run over primitives:
int numvertex = primvertexcount(0, @primnum);
int vt = vertexpoint(0, vertexindex(0, @primnum, 0));
vector ptpos = point(0, “P”, vt);
for(int i=1; i < numvertex; i++)
int pt_n = vertexpoint(0, vertexindex(0, @primnum, i));
ptpos += point(0, “P”, pt_n);
vector centroid = ptpos/numvertex;
int newpt = addpoint(0, centroid);
vector prim_n = prim_normal(0, @primnum, @s, @t);
removeprim(0, @primnum, 1);
Aleksei Rusev
Sr. Graphics Tools Engineer @ Nvidia
Stalkerx777
Wouldn't this be enough?addpoint(0, @P);
FX Supervisor
Method Studios, NY
tamte
Stalkerx777
Heh, yes, you right Tomas This code is my old one, my shame :wink:
Aleksei Rusev
Create arrow geometry which is useful for gnomons:
int createLine ( int pt0; int pt1 )
    int pr = addprim ( geoself ( ), "polyline" );
    addvertex ( geoself ( ), pr, pt0 );
    addvertex ( geoself ( ), pr, pt1 );
    return pr;
int createPolygon ( int pt0; int pt1; int pt2 )
    int pr = addprim ( geoself ( ), "poly" );
    addvertex ( geoself ( ), pr, pt2 );
    return pr;
int createPolygon ( int pt0; int pt1; int pt2; int pt3 )
    addvertex ( geoself ( ), pr, pt3 );
    return pr;
void createAxisGeometry ( float s; vector n; vector t; vector c; int color; int arrow; int scale )
    vector p [ ];
    push ( p, 0 );
    push ( p, set ( s, 0, 0 ) );
    if ( arrow )
        float x = scale ? 0.75 * s : s - 0.25;
        float y = 0.03 * ( scale ? s : 1 );
        push ( p, set ( x, y, y ) );
        push ( p, set ( x, y, -y ) );
        push ( p, set ( x, -y, y ) );
        push ( p, set ( x, -y, -y ) );
    for ( int i = 0; i < arraylength ( p ); ++i )
        matrix3 xform = dihedral ( { 1, 0, 0 }, { 0, 0, -1 } ) * lookat ( 0, n );
        p [ i ] = p [ i ] * xform + t;
    int pt [ ];
        pt [ i ] = addpoint ( geoself ( ), p [ i ] );
    if ( color )
        for ( int i = 0; i < arraylength ( pt ); ++i )
            setattrib ( geoself ( ), "point", "Cd", pt [ i ], -1, c, "set" );
    createLine ( pt [ 0 ], pt [ 1 ] );
    if ( arrow )
        createPolygon ( pt [ 1 ], pt [ 2 ], pt [ 3 ] );
        createPolygon ( pt [ 1 ], pt [ 3 ], pt [ 5 ] );
        createPolygon ( pt [ 1 ], pt [ 5 ], pt [ 4 ] );
        createPolygon ( pt [ 1 ], pt [ 4 ], pt [ 2 ] );
        createPolygon ( pt [ 2 ], pt [ 4 ], pt [ 5 ], pt [ 3 ] );
createAxisGeometry ( ch("s"), chv("n"), chv("t"), chv("c"), chi("color"), chi("arrow"), chi("scale") );
You need to create Cd point attribute before the AttribWrangle as AFAIK there is no other way to do this in code for points since setpointattrib doesn't create a new attribute and this code runs in Detail mode.
Edited by animatrix_ - Dec. 10, 2023 09:27:33
for(int i = 0; i< @numvtx; i++){
int vtx1,vtx2;
if(i<@numvtx-1){
vtx1 = i;
vtx2 = i+1;
else{
vtx1 = i;
vtx2 = 0;
int lvtx1 = vertexindex(0,@primnum,vtx1);
int pt1 = vertexpoint(0,lvtx1);
int lvtx2 = vertexindex(0,@primnum,vtx2);
int pt2 = vertexpoint(0,lvtx2);
int prim = addprim(0,“polyline”);
addvertex(0,prim,pt1);
addvertex(0,prim,pt2);
removeprim(0,@primnum,0);
Convert to polgon to polyline. Use clean sop to remove overlap.
jerry7
What's the difference with Ends SOP?
Aleksei Rusev
Stalkerx777
Ends convert one primitive to one polyline。These code convert one segment to one polyline after that can do something foreach segment.
Orient piece of geometry by 4 points:
1. src_pt - source point 1
2. dst_pt - destination point 1
3. src_opt - source point 2
4. dst_opt - destination point 2
int src_pt = 10 ;
int dst_pt = 2 ;
int src_opt = 11 ;
int dst_opt = 3 ;
vector4 q = dihedral( point(geoself(), “P”, src_pt)-point(geoself(), “P”, src_opt), point(geoself(), “P”, dst_pt)-point(geoself(), “P”, dst_opt) );
@P = qrotate(q, @P)+point(geoself(), “P”, dst_pt)-qrotate(q, point(geoself(), “P”, src_pt));
https://gumroad.com/alexeyvanzhula [gumroad.com]
v@N = random(@P*123.465) *(vector)2 - 1;
Quick Randomize vector (-1 to 1)
Ferry Taswin
Don't you want to normalize the vector as well?
v@N =normalize(random(@P*123.465)) *(vector)2 - 1
Edit: but in H14.0, you might want to look at the new sample_direction_uniform function. For example:
v@N = sample_direction_uniform(vector2(random(@ptnum)));
Here is one to clip points similar to the clip sop:
float dotprod = dot(chv(“clip_dir”),normalize(chv(“clip_pos”)-@P));
if( dotprod > 0 )
removepoint(geoself(),@ptnum);
tamte
Stalkerx777
brilliant…Thanks!
Werner Ziemerink
Head of 3D
www.luma.co.za
Peak SOP with the ability to use any attributes for Normal and Scale
float s = 1;
if ( chi("scale") )
    s = @scaleAttribute;
@P += normalize ( @N ) * ch("amount") * pow ( s, ch("exponent") );
I attached the preset that has the right parameters and mapping. You can add this to your tab menu and completely replace the standard Peak SOP.
Edited by animatrix_ - Dec. 10, 2023 09:27:57
attribwrangle.zip (1.2 KB)
Proximity
Preset attached complete with parameters.
int source = chi("source");
int index = 1 - source;
int maxpts = chi("maxpts") + index;
int handle = pcopen ( source, "P", @P, ch("maxdist"), maxpts );
int count = pcnumfound ( handle );
if ( count > index )
    int pt = pcimportbyidxi ( handle, "point.number", index );
    float dist = pcimportbyidxf ( handle, "point.distance", index );
    i@nearestpt = pt;
    @nearestdist = dist;
i@nearestcount = count - index;
pcclose ( handle );
Edited by animatrix_ - Dec. 10, 2023 09:28:42
attribwrangle.zip (1.1 KB)
marks prims with normals facing away from the origin with an attribute
vector primN = prim_normal(0, @primnum, 0, 0);
i@awayFacing = dot(primN, -@P) < 0 ? 1 : 0;
-G
oh yeah, set your attribWrangle to run on prims
-G
Random Orientation for Copy instancing
vector randDir = set(rand(@ptnum+252+ch(“seed”)),rand(@ptnum+281+ch(“seed”)),rand(@ptnum+294+ch(“seed”)));
float angle = fit01(rand(@ptnum+741+ch(“seed”)),-3.14,3.14);
p@orient = set(randDir.x,randDir.y,randDir.z,angle);
