Hello everyone, I'm new to Houdini and converting from Softimage. I'm in the middle of a procedural modeling tutorial and can't find a VOP SOP node and used VOP Attribute node instead is this new to version 14? Also, when inside a if then node I can't seem to locate the add point to group node is the an alternative in 14?
Thanks,
Chance
Is VOP SOP replaced by VOP Attribute
5498 4 0- chances
- 4 posts
- jlait
- 6245 posts
- chances
- 4 posts
I'm still not able to add points to group using the Attribute VOP and Set Attribute node. I'm trying to add the edge points of a grid to a group called
corners to be transformed.
I created several screen shots to help illustrate my setup.
Once this issue is solved… I'm going tackle a point wrangler node using VEX!
Thanks again for the help!
- jlait
- 6245 posts
- chances
- 4 posts
