Hey, what i the current state of Rendfarms for Houdini Indie v15?
The other topics are month and years old. 20-30 Amazon EC2-machines is to expensive! So are there currently any Farms like Rebus Renderfarm Service for Houdini that work?
It's the most issue for freelancer with Houdini that complex Simulation, renders not work on a single CAD PC.
In Maya, Blender, Modo, Lightwave, etc. you do your work and submit it to a farm with 300 Machines for ~2 Cent / Ghz and it done in 30 Minutes and you get the result per FTP.
Renderfarm again
3349 7 2- Eagle66
- 41 posts
- Andy_23
- 918 posts
- Eagle66
- 41 posts
- caesar
- 143 posts
- caesar
- 143 posts
- lakris
- 20 posts
- kevinthebright
- 208 posts
Just ran 50 frames though GM, a fairly beefy volume driven by particles into a VDB density then into a pyro solve. GM took 3 hours to render for $25.61 in credits. GM support has been very responsive and set-up is a breeze (helps if you've used Hqueue with Amazon, etc but it is easy either way).
I'll render out the next 50 overnight on my local machine and try a rough comparison.
- Andy_23
- 918 posts
