Hi there lovely community
I'm wiring our ubershader and am having a bit of a snooze fest wiring uploads of inputs in vops
I have a good naming convention so should be able to script it but am a bit baffled by the
the relevant functions:
outputNames - returns a tuple of connector names
setInput - requires indices
inputnames - tuple of input names
inputindex - gives an index from a name
there is no outputindex function - doh!!
not sure how else to do a lookup by name as i need the relevant output index for the setinput function
anybody have a workaround / alternative method for this?
connecting vops with hom
2026 4 1- megasets
- 85 posts
- dedeks2999
- 86 posts
- megasets
- 85 posts
hi dedks thanks for the post
I did have a look at this before - isn't this just for existing connections?
Maybe I have the wrong end of the stick
do you have any examples by any chance
I want to connect multiple outputs from a vop to multiple inputs of another vop by name rather than index
many thanks
many thanks
Sam Swift-Glasman
Art Director
Five AI
Art Director
Five AI
- pezetko
- 387 posts
- megasets
- 85 posts
hi pezetko
thanks for your reply
been having a look at this and i can't get the functionailty i want
it says in the docs:
This object is “read-only”. To create or edit connections, use methods on the node, such as hou.Node.setNamedInput, hou.Node.setInput, hou.Node.setFirstInput, hou.Node.setNextInput, hou.Node.createInputNode, and hou.Node.createOutputNode.
There are no setter functions available on this class that i can find unless i am missing something?
Just to reiterate - my issue is that I want to create connections based on names not indices. There is a helper function on the hou.Node object to convert input names to indices but not output names to indices - i require both
does anyone have any examples ?
any help would be most appreciated
Sam Swift-Glasman
Art Director
Five AI
Art Director
Five AI
