I can't seem to remove the grain particles crazy rotation that's occurring. Im just using the shelf tool as an example, and then copy stamping a load of spheres on to the points, once this is done, I notice the fast spinning of the individual grains. Does any one now how to remove this, and have a move physical rotation reaction to the sim?
I've tried mass, friction but with no effect?
Thanks.
H15 Grains spinning - how do I remove it?
2336 2 1- sessionbeer
- 39 posts
- jlait
- 6245 posts
Grains do not have orientation.
Copy Stamp, if missing ‘orient’ attributes, uses the ‘v’, velocity, attribute for the direction. Grains at almost-rest will have small jittering ‘v’ as they settle, this results in the wild varying directions for orientations.
If you want orientation, consider the Bullet-based grains shelf example instead.
- sessionbeer
- 39 posts
