Hi everyone, and thanks for take a time to read this post.
I ‘ve been trying to render some volumetrics in houdini with mantra, and can’t find the way to avoid fireflies that appears in my final render.
Try increasing samples, tweaking secondaries minRay and maxRay samples, as so with Noise levels, and fire flies still appears.
Any suggestions?
Thank you very much!
Esteban
Attach an image to show my issues.
Fireflies
6603 5 3- nenuco
- 18 posts
- Enivob
- 2556 posts
Here are a couple of links on the subject.
http://forums.odforce.net/topic/24974-solvedremove-fireflies-caused-by-geometry-light/#comment-145606 [forums.odforce.net]
http://forums.odforce.net/topic/23095-odd-artifacts-in-render/#comment-136450 [forums.odforce.net]
You will need to investigate how to use Extra Image planes. These are also called AOVs in other packages (arbitrary output values).
Once you separate your passes into separate images you can identify which pass contains the fireflies. This helps a lot in resolving the problem.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- sidenimjay
- 702 posts
- circusmonkey
- 2624 posts
- silkey
- 13 posts
- merlino3d
- 65 posts
