Hi there,
I have an animated object that I'm instancing onto points. Is there any way of randomizing or offsetting the animation time of the instances (point instancing or copy sop) without copy stamping them to a time shift sop. With a lot of instances the mentioned solution becomes really slow through the stamping approach so I was wondering if there's an attribute to actually control the instance time.
Thanks and best,
Roman
Instance Animation Time
7177 6 1- romen
- 5 posts
- A-OC
- 253 posts
- el_diablo
- 133 posts
- tamte
- 8599 posts
- romen
- 5 posts
- tamte
- 8599 posts
http://forums.odforce.net/topic/25971-optimize-copies-stamping-or-not-solved/?do=findComment&comment=151013 [forums.odforce.net]
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- romen
- 5 posts
