Hi
I'm writing a renderer and exporting the geo to the format I need takes
the most time specially with geometry with millions of points of course
I think there was a post a while back about this, to process the geometry faster
can't find it
any tips?
use numpy maybe?
an external C++ parser maybe?
any tips are welcome
thanks
Process SohoGeometry faster, tips
2159 4 1- varomix
- 460 posts
- Enivob
- 2563 posts
Here are some basic python tips…http://stackoverflow.com/questions/27384093/fastest-way-to-write-huge-data-in-file [stackoverflow.com] I would say the take away is to write chunks directly to the disk and try to avoid joins.
I put together a minor RIB exporter a while back. Mainly a Shelf Tool button, not SOHO. Interrogating the scene and preparing ASCII output can be the slowest part for an external renderer.
Is this for your Cycles ROP WIP?
Edited by Enivob - Feb. 16, 2017 16:56:09
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- varomix
- 460 posts
- Enivob
- 2563 posts
Here is some code exploration I did on the camera matrix when writing a .RIB exporter.
I broke my exporter into separate sections. For instance I would fetch all top level Geometry nodes then get their children and look for the display flag. Then I would execute the saveToFile() method on that to generate a .obj version of that geometry network on disk.
Does Cycles read any native model format? Like .obj, .ply, .stl etc…? If so, the saveToFile() might speed up some export operations.
n = hou.node(camera_name) if n != None: fl = n.parm("focal").eval() fu = n.parm("focalunits").eval() ap = n.parm("aperture").eval() nc = n.parm("near").eval() fc = n.parm("far").eval() ic = n.parm("iconscale").eval() rx = n.parm("resx").eval() ry = n.parm("resy").eval() pr = n.parm("aspect").eval() sh = n.parm("shutter").eval() fd = n.parm("focus").eval() st = n.parm("fstop").eval() mtx = n.parmTransform() delight_matrix = hou.Matrix4( (0,0,1,0, 0,-1,0,0, 1,0,0,0, 0,0,0,1) ) # Swap X<->Z, Y negative. mtx = mtx * delight_matrix pos=mtx.extractTranslates() rot=mtx.extractRotates() scl=mtx.extractScales() safe_node_name = n.name().replace("/","_") file.write('#-> Camera %s\n' % safe_node_name) #file.write('DepthOfField %f 1.0 %f\n' % (st, fc)) #file.write('Shutter %f %f\n' % (rm.shutter_open, rm.shutter_close)) #file.write('Option "shutter" "efficiency" [ %f %f ] \n' % (rm.shutter_efficiency_open, rm.shutter_efficiency_close)) file.write('Clipping %f %f\n' % (nc,fc)) #fov = 2 * math.degrees(math.atan(16.0 /(aspect * self.camera.lens))) #Blender file.write('Projection "perspective" "fov" [%f]\n' % fl)
# Export geo based objects as OBJ files. lst_geo_objs = [] lst_mat_counts = [] nodes = childrenOfNode(hou.node(node_root_path),["Object geo"]) #Other valid filters are Sop, Object, cam. for node in nodes: ary = node.split("~") if len(ary) > 0: node_candidate = "%s/%s" % (node_root_path, ary[0]) n = hou.node(node_candidate) if n !=None: if n.isDisplayFlagSet(): mat_count = exportAsOBJ(node_candidate, geo_dir, current_frame) lst_geo_objs.append(node_candidate) lst_mat_counts.append(mat_count)
- varomix
- 460 posts
