My understanding was that my license of Indie would allow me to open other version files, but that there would be limitations to which versions could open which files.
I am finding that when I load project files from the Masterclass - such as the project files for the changed Oceans, I get a lot of error on opening - - usually “Skipping unrecognized parameter” errors, and often black screens or odd behavior.
Are the tutorials not set up for Indie folks? I know that my Digital Tutors sub had issues because you couldn't open ‘real’ Houdini files in APPRENTICE, but I would hate to find out that I can't utilize training resources with Indie.
EDIT: Another example - -for the file ocean_waves_baked, I get the unrecognized parameter errors, but it loads and SEEMS to work, but then if I attempt to render I get an error about being unable to load two textures.
Thanks,
Masterclass and Other Sample File Formats
2067 1 1- phloog
- 13 posts
- malbrecht
- 806 posts
Moin,
“skipping unrecognized parameter” sounds like if you are trying to open a H16 file with a H15 version (or some similar setup where you try to open a newer version HIP with an older version of Houdini). Are you using the latest version of Houdini?
I could imagine the other way around (older file version) could, sometimes, lead to issues as well - could you give some more details on what version the tutorial files where created in and what version you are running yourself?
Marc
Marc
Good bye.
Good bye.
