Accessing particle attributes in new POP network
   2036   2   0
Hi, i was trying to access color (Cd) attribute in POP Force, to move my particles, using ‘$CR’, but it seems that those are not defined. In the old POP network, you could use that i.e. Accelerate node.
What is the ‘correct’ way to use attributes in the new (Houdini >= 15) POP network? I know that i can use POP VOP, but it would be nice to use them in existing nodes.
Cheers
-kimmo
check Vex expression.
Then you can use @Cd.x = whatever . etc.
Hmmm..doesn't seem to work
-k
