Hello Everyone,
I'm in the process of building a small personal render farm(Houdini FX)and need some help from anyone that has experienced the same issues.
I have two workstations right now both running Windows 10 Proffesional.
The main workstation with Houdini FX will also be the file server, licensed Server, and HQueue Server.
The second computer will be client. Once this is working correctly I will add an additional 3-5 clients.
I tested the two computer configuration with Modo and everything connects and renders accoss the network.
The issue I'm having right out the gate is the client is not showing up when selecting the add client button.
When installing the client I added the path to the HQueue server by entering the computer name replacing localhost in field. I checked the service and it's running.
When trying to add the client from HQueue Server it says I can't load from browser.
I'm kind of stuck at the moment.
Anyone experience something similar?
Thanks,
Chance Norris
Problem Setting up HQueue On Windows 10
1664 0 0- chances
- 4 posts
