I have a node connected to an attributeWrangle with these attributes :
- weight1,weight2,weight3
- nWeights=3
How can I loop through the 3 weights to get their values inside the wrangle node ?
Thanks,
Julien
Loop through inputs attributes in VEX
11812 8 4- julien-b
- 66 posts
- BabaJ
- 2042 posts
- kahuna031
- 897 posts
Sounds like you can put the attributes in a string with a chs() expression, split that to an array, loop over the attributes:
foreach (string attribName; splitArray){
point (0, attribName, @ptnum)
Edit: missed the nWeight attribute.
Do a for loop instead.
for (int i =1; i <nWeight+1;i++){
point (0,“weight”+itoa (i), @ptnum)
Edited by kahuna031 - April 4, 2017 16:01:13
B.Henriksson, DICE
- trzanko
- 24 posts
This computes the normalized sum and colors the points by the normalized weights for visualization, given multiple attributes called attrib0, attrib1 …. attribn. It sorts through all your attribs so no need to hard code anything besides the name prefix.
Hope this helps, it'd be nice if the paint weights node code also work on arbitrary attribs or allow you to create them by painting multiple new attrib regions. Bone capture weights are a unique kind of packed data that could be engineered to work but it requires captured bones to setup.
string ats[] = detailintrinsic(0,"pointattributes");
float wts[];
vector cds[];
float sum = 0;
//create attrib array and compute the sum
for(int i = 0; i < len(ats); i++){
string s = ats[i];
if(startswith(s,"attrib")){
float val = point(0,s,@ptnum);
append(wts,val);
append(cds,rand(i));
sum += val;
//normalize weights & color
@Cd = 0;
for(int i = 0; i < len(wts); i++){
float normVal = wts[i] / sum;
vector normCd = cds[i] * normVal;
@Cd += normCd;
wts[i] = normVal;
Tighe Rzankowski
trzankofx@gmail.com
trzankofx@gmail.com
- sberger
- 3 posts
- neil_math_comp
- 1743 posts
For future reference, you can find what all of the detail intrinsics are, either by going to the Geometry Spreadsheet, going to the detail tab, then checking the Intrinsics drop-down, or by (in a somewhat meta way), reading the
globaltokens
detail string array intrinsic. All of them can be read from VEX using the detailintrinsic
function. You can do a similar thing with primitive intrinsics on the primitive tab, or using the primitivetokens
primitive string array intrinsic, and the primintrinsic
VEX function.
- jingyukan
- 10 posts
kahuna031
Hello, I have a similar problem, since I am quite new to vex language, would you mid be more specific? Like I have 200 columns in geometry spreadsheet as attributes, and I want to take each column with name “water_conc0”,“water_conc1”,“water_conc2”… and fit each data into range 0 - 1 using fit01() function, so that I could get 200 columns of 0 - 1 data.
But I don't know how to use the for loop to achieve this.
Thanks in advance!
This iterated code could illustrate what I want to achieve~
Edited by jingyukan - June 8, 2020 17:05:06
- mestela
- 1746 posts
Looking at your screenshot there, this is one way to convert that into a loop:
string src, dest, prefix, newprefix; int range; float value, min, max; prefix = 'water_conc'; newprefix = 'waterCd'; range = 8; min = 264; max = 142; for (int i=0; i<=range; i++) { src = prefix+itoa(i); // construct the source attribute name dest = newprefix+itoa(i); // construct the destination attribute name value = point(0,src,@ptnum); // read the value value= fit(value, min,max,0,1); // fit setpointattrib(0,dest,@ptnum,value); // set the value }
- jingyukan
- 10 posts
mestela
Looking at your screenshot there, this is one way to convert that into a loop:string src, dest, prefix, newprefix; int range; float value, min, max; prefix = 'water_conc'; newprefix = 'waterCd'; range = 8; min = 264; max = 142; for (int i=0; i<=range; i++) { src = prefix+itoa(i); // construct the source attribute name dest = newprefix+itoa(i); // construct the destination attribute name value = point(0,src,@ptnum); // read the value value= fit(value, min,max,0,1); // fit setpointattrib(0,dest,@ptnum,value); // set the value }
Thanks so much!!
