Principled shader and procedural bump map (noise)
   Views 9080   Replies 6   Subscribers 1
Anyone knows how to connect a procedural texture (noise for instance) to the bump map of the new principled shader ?
if I use “bump & normals” tab there is only a “texture path” string parameter
and the inputs for bump are all strings except bump scale and filter width
Thank you
Edited by madrenderman - May 16, 2018 05:31:36
I highly recommend you watch this:
https://www.sidefx.com/tutorials/houdini-16-masterclass-custom-shading/ [sidefx.com]
Its the brand new masterclass…
Yes I watched it …
Probably it's not possible to do it using the pre-built normal and bump inputs in the principled shader but I guess I have to use material builder node
We very recently added new inputs in the “Other” group, where you also find custom uvs and displacement. Try it with the latest build!
Kai Stavginski
Senior Technical Director
I found that if you plug your procedural bump map into a ‘displace along normal’ node first, you can then plug the output dispN from that into the baseN or CoatN on the principled shader.
Thank you I'll try that
