hello
I couldn't figure out how I can use Bindings > Geometry feature in almost all dops other than Binding simulation to “Geometry” data of the simulation.
and I can't find a proper example to enlighten me about it.
please if you can help, let me know how It can be useful other than that mean.
thank you in advance
dop binding
6438 4 1-
- MirHadi
- 147 posts
- tamte
- 9088 posts
- MirHadi
- 147 posts
tamte
but you can operate on any geometry data that belongs to the object this solver is solving
thank you Tomas!
that is exactly what I can't figure out…
for example, a geometry data from a popsolver, how can it be used other than Geometry?
for instance, the velocity data of popsolver to operate on relathionship data instead of the velocity of points…?
I hope It makes sense..
- malbrecht
- 806 posts
Moin,
depends on what “geometry data” you mean. If you are referring to the position of points (which in my world is “geometry data”), you can use a Rivet node (I have a 1n1v on that :-) ) to get position data from single points or more up into scene level, e.g. for parenting objects.
… if you are referring to attributes, you can use areference to get point attribute values and use them in channels.
Marc
point(...)
Marc
Good bye.
Good bye.
- tamte
- 9088 posts
hadi jam
…for example, a geometry data from a popsolver, how can it be used other than Geometry?
you can use it to modify any geometry data that belongs to the object, not sure if you can access relationship geo like that though, that may need to be attached to the node that created relationship like is the case of constraintnetwork, but I may be wrong
but for sure any geometry data that you see in Spreadsheet that belongs to the object you are solving
Edited by tamte - April 27, 2017 23:12:32
