Tried to install Apprentice few times with no luck.
I use Windows7 Pro.
I use home network wirh wireless modem.
Got all kinds of errors.
Has anybody solved this issues?
If so please share your solutions.
Can't install Houdini Apprentice Windows7
2292 2 2- musolo
- 4 posts
- malbrecht
- 806 posts
Moin,
> Got all kinds of errors. Has anybody solved this issues?
that is a very helpful description of your problem: “all kinds of errors”. Would you mind posting those “all kinds”? It might help others to figure out what problems you are having.
There are a lot of threads on getting the license system up and running around this forum, so you probably have read them all and tried the suggestions made there - that should already enable you to narrow down the probable cause, it would help if you could tell your findings.
If you do not wish to provide such information in public, which is fine, you might get better help from support@sidefx.com - since they are quite professional about the various issues that can or can not make licensing difficult.
Marc
Marc
Good bye.
Good bye.
- musolo
- 4 posts
I tried to install it four times and made screenshots of all the errors and when i came on this forum with all this errors ‘documented’and screenshots attached and wrote my messages guess what happened. - Messages were not published saing
- looks like it's your first message our moderator will ……..
Got this twice.
And i must say it was quite terribe feeling after all shis nonsence to get this kind of kick in a balls.
There is very bad start with it clearly and i'm not sure if i want to have that joy of wierdest installation in my life once more. Not today for sure.
This thread is for those who had some bad luck and want to try this package and couldn't run it on Windows7.
Maybe there are a few enough to solve this puzzle
When i'll make my next try tommorow i'll post screenshots or video of ‘installation’ process.
Got this twice.
