Hello guys.
Just curious to know how these functions compute intersecting position?
Any explanation would be appreciated.
How does intersect(_all) VEX function work?
10399 15 3- Nima
- 471 posts
- malbrecht
- 806 posts
do you mean “how do they do it mathematically” or do you mean “how do they do it so that the user can benefit from it”?
As for the later … my “environment aware animation rig” tutorial shows how to use the function at around minute 10:38 (according to the directory at the beginning of the video )
https://vimeo.com/211124606 [vimeo.com]
Marc
Marc
Good bye.
Good bye.
- Konstantin Magnus
- 686 posts
I guess Nima rather wants to know how it's computed. But if someone's interested in how to use the function first, here goes:
// Custom ray direction and range vector dir = {0, -8, 0}; // Results will be stored in these two vectors vector pos; vector uvw; // which primitive has been hit is stored in (int prim) // shoots points on geo of the second input (@OpInput2) // uses current position (@P) // uses direction and range of (dir) // stores the new position to (pos) // stores the exact location on primitives in (uvw) int prim = intersect(@OpInput2, @P, dir, pos, uvw); // assigns pos to point position (@P) if(prim>=0){ @P = pos; // transfers colors from 2nd input to point colors (@Cd) @Cd = primuv(@OpInput2, "Cd", prim, uvw); }
Edited by Konstantin Magnus - April 30, 2017 16:07:38
- malbrecht
- 806 posts
yeah, that's the short form :-) The only point I'd like to add is that you should check “prim” for being greater or equal zero. Because it can be “-1” if there is no intersection found either in the direction given or within the range (length of the direction vector). By ignoring that your “@P” can get false values.
Marc
Marc
Good bye.
Good bye.
- Nima
- 471 posts
- Konstantin Magnus
- 686 posts
Hi Marc,
you're correct. I added an if statement to my example code and file.
- tamte
- 8844 posts
NimaI guess if you research raytracing, building acceleration structures, ray/plane, ray/poly, ray/… intersections you will get the idea how they work matematically, or at least what algorithms are out there to write similar functions from scratch
I know how to use them but I don't now how do they do it mathematically.
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- malbrecht
- 806 posts
I don't know how Houdini is doing it specifically, but in general I'd say the approach is:
- check if the ray is parallel to the plane of each polygon you need to check (this you can get from a octtree for all points within the sphere described by the ray length)
- if yes, bail out: No intersection
- if no, we might have an intersection, now gow through all “edges” on each polygon in question and check if a potential point on the ray lies on the same side (“inside the polygon”) of the ede
- if no, bail out for this polygon and continue with next, no intersect found so far
- if yes, we got a hit: Now all you do is get the weight for the points describing the hit-polygon and write those to “UV” coordinates
@Konstantin: If I am allowed to nitpick again … I'd also add a fail-condition to write some “meaningful” values to “@P” if no intersection is found (i.e. for “prim=-1”) …
Marc
Marc
Good bye.
Good bye.
- Nima
- 471 posts
tamteThanks Tomas.NimaI guess if you research raytracing, building acceleration structures, ray/plane, ray/poly, ray/… intersections you will get the idea how they work matematically, or at least what algorithms are out there to write similar functions from scratch
Have you any good reference for raytracing?
In wikipedia, I saw a C++ code for pathtracing but not for raytracing.
This was (Algorithm section):
https://en.wikipedia.org/wiki/Path_tracing [en.wikipedia.org]
@Mark:
The challenge is how to do this line:
The main problems are two things:
1-Time complexity.
2-Massive data when these functions need to be done on a dense model.
Edited by Nima - April 30, 2017 16:37:48
- Konstantin Magnus
- 686 posts
malbrechtyes, sure!
malbrechtbut why?
if it's -1, the points just stay where they are!
- malbrecht
- 806 posts
> but why?
… if that is “meaningful”: Absolutely fine!
My thought was that if the code snippet is to demonstrate the overall function, that case (which is a valid one) should be handled, even if it was just with “@P=@P” - or, even more minimalistic, a comment.
I did mention I was going to “nit pick”, right?
Marc
Marc
Good bye.
Good bye.
- Konstantin Magnus
- 686 posts
malbrecht
No, no, you are totally right. For educational purposes there should be an else statement, as well.
@nima: sorry for having gone off-topic.
- tamte
- 8844 posts
maybe search for ray casting as that may be more of what intersect does, but ray tracing and path tracing are all using it so never hurts to broaden your horizons, I'm not really into C++ so I don't really know which resources are the best, but there is a plenty of ray/pathtracing books that will have to describe ray casting at some point so I guess any of them will work
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Nima
- 471 posts
- neil_math_comp
- 1743 posts
To confirm what was guessed above, if intersect is called, VEX builds and caches an acceleration structure for the geometry that's being intersected, which can take quite a bit of time, but makes additional calls faster. For example, if the geometry being intersected has a lot of primitives in it, calling intersect 100,000 times (e.g. once for each of 100,000 points being run over) might not be much more expensive than calling it once, because of the time spent building the acceleration structure. It's been a while since I profiled the performance, though, so I don't have specific timing data for ya.
- rafaels
- 700 posts
Hi, just stumbled upon this, as I’m doing some ray casting of my own… how is the acceleration structure cached? Suppose I’m running the vex code in a wrangle, would there be a pragmatic benefit in building an acceleration structure myself?
Rafael
Rafael
Toronto - ON
