Bake procedural texture Cd to uvs
10414 8 3- merlino3d
- 65 posts
- Enivob
- 2565 posts
The simple way is to just place a camera above the grid so it is framed exactly to the size of the grid and render out a single frame, or an image sequence if your procedural texture is animated.
But I would like to know if there is a better way then that?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- madrenderman
- 129 posts
- merlino3d
- 65 posts
- Konstantin Magnus
- 670 posts
If its just a regular grid, you wont need baking after all. There is an importpoint node in COPs that can read in attributes from geometry. Just make sure the grid resolution matches the image size. It also works for animation.
- Enivob
- 2565 posts
Thanks for the example file, that is good to know.
I thought I would try an attribute from map and see it that could be “relayed” but it does not seem to work. I have assigned the map to Cd but COPs does not pick up on that. It seems like a refresh problem. Is there a way to make COPs refresh and pick up the new data?
Edited by Enivob - May 27, 2017 09:32:39
- Konstantin Magnus
- 670 posts
- stronglikebool
- 28 posts
- Enivob
- 2565 posts
