Ive made a human model in zbrush, exported it as an obj.file and added a skin material to it.
In zbrush i made a diffuse, normal and displacement map, these are included in the obj.
Im all new to Houdini, and having a hard time setting up my nodes in the VEX builder.
I managed to add my diffuse texture to the skin shader node. But when i try adding the Normal Map and displ. map, i cant get any result(at least a good one).
Is there a good tutorial out there? Been searhing for 3 days, but cant seem to find any good setup for human skin in houdini.
Thanks for any help!
Skin Material. How to add Normal and displacement texture?
2700 2 0- arhusvegard
- 19 posts
- Enivob
- 2568 posts
I'm not sure what shader you are actually using but I have found that the Classic shader has the displace/normal effect amount default to 1.0. This does produce an excessive amount of bump/displacement. I often drop it quite low like 0.1 or smaller.
Edited by Enivob - June 2, 2017 10:12:08
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- arhusvegard
- 19 posts
