Hello everyone
I have been trying to get houdini to work well with arnold and I have been having a very hard time. In order to debug the issue I decided to run houdini from the terminal by running
cd /Applications/Houdini/Houdini16.0.600/Houdini FX 16.0.600.app/Contents/MacOS
./houdini
The application then starts, but after several seconds it crashes with a long traceback.
File “<string>”, line 9, in <module>
File “/Applications/Houdini/Houdini16.0.600/Frameworks/Houdini.framework/Versions/16.0.600/Resources/houdini/python2.7libs/hou.py”, line 56010, in <module>
import houpythonportion
File “/Applications/Houdini/Houdini16.0.600/Frameworks/Houdini.framework/Versions/16.0.600/Resources/houdini/python2.7libs/houpythonportion.py”, line 6, in <module>
import gzip
File “/usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/gzip.py”, line 10, in <module>
import io
File “/usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/io.py”, line 51, in <module>
import _io
ImportError: dlopen(/usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so, 2): Symbol not found: __PyCodecInfo_GetIncrementalDecoder
Referenced from: /usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so
Expected in: flat namespace
in /usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so
PyClerk: Traceback (most recent call last):
File “<stdin>”, line 1, in <module>
File “/Applications/Houdini/Houdini16.0.600/Frameworks/Houdini.framework/Versions/16.0.600/Resources/houdini/python2.7libs/shopclerks/i3dclerk.py”, line 5, in <module>
import hou
import gzip
import io
import _io
PyClerk: No getName() method found
File “/Applications/Houdini/Houdini16.0.600/Frameworks/Houdini.framework/Versions/16.0.600/Resources/houdini/python2.7libs/shopclerks/ifdclerk.py”, line 5, in <module>
import hou
import gzip
import io
import _io
File “/Applications/Houdini/Houdini16.0.600/Frameworks/Houdini.framework/Versions/16.0.600/Resources/houdini/python2.7libs/shopclerks/ribclerk.py”, line 5, in <module>
import hou, sys
import gzip
import io
import _io
00:00:00 261MB | log started Wed Jul 19 22:09:34 2017
00:00:00 261MB | Arnold 5.0.0.2 darwin clang-3.9.1 oiio-1.7.12 osl-1.8.2 vdb-4.0.0 rlm-12.2.2 2017/05/08 11:44:15
00:00:00 261MB | running on CDM-RITCHIE-10.local, pid=21769
00:00:00 261MB | 1 x Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz (4 cores, 8 logical) with 16384MB
00:00:00 261MB | OS X 10.11.6 “El Capitan”, Darwin kernel 15.6.0
00:00:00 261MB | soft limit for open files raised from 4864 to 10238
00:00:00 261MB |
00:00:00 261MB | Registering shaders …
00:00:00 261MB | loading plugins from /Users/rudy/htoa/htoa-2.0.1_r9019629_houdini-16.0.600/htoa-2.0.1_r9019629_houdini-16.0.600/arnold/plugins …
00:00:00 261MB | htoa_mandelbulb_proc.dylib: mandelbulb uses Arnold 5.0.0.2
00:00:00 261MB | loaded 1 plugins from 1 lib(s) in 0:00.02
00:00:00 261MB | Loading metadata file: /Users/rudy/htoa/htoa-2.0.1_r9019629_houdini-16.0.600/htoa-2.0.1_r9019629_houdini-16.0.600/arnold/metadata/cameras.mtd
00:00:00 261MB | Loading metadata file: /Users/rudy/htoa/htoa-2.0.1_r9019629_houdini-16.0.600/htoa-2.0.1_r9019629_houdini-16.0.600/arnold/metadata/lights.mtd
00:00:00 261MB | Loading metadata file: /Users/rudy/htoa/htoa-2.0.1_r9019629_houdini-16.0.600/htoa-2.0.1_r9019629_houdini-16.0.600/arnold/metadata/options.mtd
00:00:00 261MB | Loading metadata file: /Users/rudy/htoa/htoa-2.0.1_r9019629_houdini-16.0.600/htoa-2.0.1_r9019629_houdini-16.0.600/arnold/metadata/shaders.mtd
00:00:00 263MB | Loading metadata file: /Users/rudy/htoa/htoa-2.0.1_r9019629_houdini-16.0.600/htoa-2.0.1_r9019629_houdini-16.0.600/arnold/metadata/shapes.mtd
00:00:00 265MB | shader registration done.
00:00:00 265MB |
00:00:00 265MB | releasing resources
00:00:00 264MB | Arnold shutdown
libc++abi.dylib: terminating with uncaught exception of type HOM_Error
Abort trap: 6
I have searched for several hours and I have not been able to find anything helpful. Does anyone have any tips on how to solve this?
Thanks so much!
Rudy
Cant run houdini from the terminal for debugging purposes HOU 16.600 OSX Sierra
4486 6 2- rcortes9
- 2 posts
- anon_user_37409885
- 4189 posts
- Anthony Dias
- 5 posts
Hello rcortes9,
did you ever find a solution to this? I'm having a very similar issue. I run the Houdini Terminal app by double-clicking it in the finder. This sets up the environemnt if I understand correctly. I then type “hindie” and it starts Houdini but then crashes:
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fffbced5d42 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fffbcfc3457 pthread_kill + 90
2 libsystem_c.dylib 0x00007fffbce3b420 abort + 129
3 libc++abi.dylib 0x00007fffbb99584a abort_message + 266
4 libc++abi.dylib 0x00007fffbb9bac4f default_terminate_handler() + 267
5 libobjc.A.dylib 0x00007fffbc4c8353 _objc_terminate() + 124
6 libc++abi.dylib 0x00007fffbb9b7d69 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fffbb9b77de __cxa_throw + 121
8 libHoudiniUT.dylib 0x000000011c4a836a HOM() + 170
9 libHoudiniUI.dylib 0x000000010e403bc9 SI_PythonShell::initApplication(UI_Manager*, int, char const**) + 25
10 libHoudiniAPPS2.dylib 0x00000001084887d5 OPUI_MainApp::initApplication(UI_Manager*, int, char const**) + 2165
11 libHoudiniUI.dylib 0x000000010e1ac6b8 main + 3848
12 libdyld.dylib 0x00007fffbcda7235 start + 1
abort() called
- jonahtobias
- 21 posts
To completely fix python on Mac OS follow these steps in OS X terminal.
You'll need to have homebrew installed (https://brew.sh).
BTW I am running macOS 10.13.3 and these steps work well. I can't vouch for it working under newer version of OS x.
First try fixing your existing python installation:
If that doesn't do it you may need to completely reinstall python on your mac.
You will need to install Xcode (https://developer.apple.com/xcode/). This is deep surgery and could screw up your system python terribly but it worked flawlessly for me:
brew cleanup sudo pip install --upgrade virtualenv
sudo rm -rf /Library/Frameworks/Python.framework/Versions/2.7 sudo rm -rf "/Applications/Python 2.7" ls -l /usr/local/bin | grep '../Library/Frameworks/Python.framework/Versions/2.7' cd /usr/local/bin/ ls -l /usr/local/bin | grep '../Library/Frameworks/Python.framework/Versions/2.7' | awk '{print $9}' | tr -d @ | xargs rm brew uninstall python sudo xcode-select -r brew update && brew reinstall python
Edited by jonahtobias - Sept. 8, 2018 18:43:52
- Len
- 132 posts
Does anyone know of a fix for launching Houdini from Terminal on a Mac? I get tons of python errors, no GUI, and quits back to terminal.
I'm dying for some VEX printf() capability on Mac Houdini.
The above Home Brew technique fails on a DVTFoundation error.
Trying Houdini Indie 16.0.75 with OS 10.12.6
Launching from the dock works fine.
Thanks.
UPDATE: It works! I pushed through the Home Brew errors I was getting and followed the instructions above (had to re-install python). Now I can launch the terminal app and type “hindie” and I can see printf statements on my MacBook! Hurray! Thank you!!
If you run into the 64/32 bit python issue, start here: https://docs.brew.sh/Installation.html [docs.brew.sh]
And make sure you have everything needed. Then follow jonahtobias' other instructions. I also launched Xcode manually to make sure all the licensing was approved. But that's it.
Thanks.
Edited by Len - Oct. 23, 2017 12:08:58
- Len
- 132 posts
