Hi guys!
I'm trying to mix a simple keyframe animation with a RBD, I tried using an active value and OBJ position node after the RBD Packet Object node (has the example on houdini help), and I can't set the OBJ position when activate the dynamics.
I also tried the Deactivate Objects tool from the shelf and the result is the same, the object position when the DOP is active its not correct (in this example I followed Peter Quint tutorial “Keyframe /DOP 1”)
If I set the the object position in the RBD packed object transform node it increments the position on the object level.
Any help?
Mixing Keyframe animation and dynamic simulations
4902 1 1- joaoalexdias
- 15 posts
- pwquint
- 53 posts
Hi
The tutorial on Dops keyframes was made before RBD packed objects existed. In general the easiest way to manipulate packed objects is to use a SOP solver. Inside the solver the packed objects will look like a set of points with attributes on them, one point per object. For example setting the active attribute on a particular point will determine if that object is simulated, changing the position (P attribute) will move it. The RBD packed object helpcard has some details of the attributes.
I did a tutorial on the sop solver some time ago. It is still valid with a minor modification on how you wire in the solver if I remember right. I believe the project file was updated to work in more recent versions of Houdini and is commented.
https://vimeo.com/6660287 [vimeo.com]
Edited by pwquint - Aug. 4, 2017 08:20:12
Peter Quint
