Is there a way to use Carve SOP and provide the first U/Second U in meters rather than a U parameter (0..1) ?
I have real world measurements curves (adaptively sampled, so more points where more curvature) and I need to “shave off” a specific length.
Carve by arclength instead of parametric 0..1 ?
4168 9 2- geometryNerd
- 11 posts
- dedeks2999
- 86 posts
- matthias_k
- 483 posts
- vusta
- 555 posts
- Aizatulin
- 480 posts
just in addition, you can also create a carve tool with the attribute wrangle. After you've calculated the length for a curve (arclen not working in wrangle for me ?!), you can use the length to build your own curve by defining a curve function by another wrangle. Resampling is useful before (it is doing the main work), to get an uniform sampled curve.
- dedeks2999
- 86 posts
hye Aizatulin,
Did you try this function in your code ?
http://www.sidefx.com/docs/houdini/vex/functions/primarclen.html [www.sidefx.com]
Apparently, you can also get it from the arclength primitive intrinsic attribute
— dedeks 3000 —
- Aizatulin
- 480 posts
- dedeks2999
- 86 posts
- Aizatulin
- 480 posts
- Octop
- 13 posts
