Hey,
I'm about Grid, Orthogrid… Display Normals/ Points… these all except Display Options.
Maybe I just don't see them in Edit Radial Menu? Can't find both in Shelves and Nodes panels.
If they are not there - can they be added somehow using for example scripts or something if it's explainable?
Thanks for possible advices.
Adding viewport's right-side tools/options to Radial Menu?
1307 2 1- RyuKu
- 171 posts
- harryabreu
- 76 posts
Hi Ryu ku welcome to Houdini's world
Probably your answer reside on Python in Houdini with python you can personalize the interface and a little script will help you a lot.
Sorry my knowledge is short but wait a little more someone with more proficiency can help you better
Otherwise you can use Houdini's help to see how Python work.
Edited by harryabreu - Jan. 11, 2018 07:38:21
- RyuKu
- 171 posts
Hello, harryabreu.
Thanks for welcoming.
You make me thinking that I am in the right direction with the idea that Python can help with it - saw the Script field in the Radial Menu window. There is no need to sorry for your knowledge, at least not with me - something you know more about, something I… not sure about me though. The most probably about Houdini you know way more now.
Thanks for your answer, it helps me to decrease a kind of panic/ hesitating/ worrying.
As you advice - will wait if someone can help with it.
Edited by RyuKu - Jan. 12, 2018 07:15:49
