Hi!
I would like to know how I can use a noise in a point vop to affect the distance in a polyextrude (or any node really…).
Right now, I've got a noise that I connected to a “bind” that I named “myNoise”. How to I get the “distance” of a “polyextrude” to be affected by that bind?
I'm new to houdini so be gentle!
Using vop bind to affect another node
3130 9 0- olivierth
- 1010 posts
- Enivob
- 2558 posts
Some nodes will simply allow you to type an attribute name into the field, like the width on polywire. Give it a try. Type @myNoise into the distance field. The attribute must exist on the points or primitives upstream of the node where you use it.
Edited by Enivob - Feb. 5, 2018 20:48:35
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- olivierth
- 1010 posts
- jsmack
- 7813 posts
Not all nodes work that way, polyextrude being one of them. There's currently only a few parameters on the polyextrude that can be influenced by attributes.
http://www.sidefx.com/docs/houdini/nodes/sop/polyextrude#local-control [www.sidefx.com]
- Andr1
- 118 posts
- Enivob
- 2558 posts
- Enivob
- 2558 posts
- olivierth
- 1010 posts
- Enivob
- 2558 posts
VEX is actually easier than VOPs. You have to drop down several nodes, connect them up and configure them correctly in VOPs to produce the one line of code, which is all you need for this solution.
Edited by Enivob - Feb. 6, 2018 13:24:29
- olivierth
- 1010 posts
I completely understand that the most efficient way is VEX (when you know what you're doing) but I've never been good at coding since I get zero enjoyment out of it. Someday, I'll gradually get comfortable with VEX but I'll stick to baby steps using vops for now.
No matter, thanks for helping!
-Olivier
-Olivier
