I have installed the new H16.5. When i try to constraint points on a solid object, i cant select any points on my object i dop. I know its a polygon and tried different geos, but nothing. Is there a new way to select constraint points in 16.5? I have reinstalled my whole houdini, so might be some settings in my program. Have anyone had this problem before?
regards
SOLVED: i had to use a visibility node in sops to mark my tetras.
Cant select constraints on solid object?
1275 0 0- arhusvegard
- 19 posts
