I noticed this:
I had to subdivide a group of 261k prims, which is part of a 2.5millions prims geometry.
I tried to specify the group name in the subdivide node, but after 1.5 hours (!!) of cooking, I gave up and killed the cooking… Too much time for only 261k prims (and only depth 1 subdivision).
So I tried separate the group of prims, by blasting it from the rest of the geo. I run the subdivide again, and the cooking time was now reasonable (few seconds vs 1.5+ hours).
Then I merged back the two geos together.
My question: is this an overall good practice for better efficiency that should be used with other nodes too, when u want to run a node only on a selected group of prims?
To note: the crazy slowness happened with the Houdini Catmull-Clark algorithm. Other subdivide algorithms had a reasonable cooking time when I specified the group name.
When highres geo, don't use group option on nodes, better blast the group, run the node on it, and merge it back?
1598 2 0- Andr1
- 118 posts
- anon_user_37409885
- 4189 posts
- Andr1
- 118 posts
Hello Fuos thanks for the tip,
I just sent a support request to SESI after further testing.
I will report what the support team say, but so far I noticed this:
The houdini catmull-clark algorithm struggles when it is applied to a GROUP of prims, probably for its unique ability of closing the produced holes (which is why I need to use the specific algorithm).
In my case it became super slow because my geo is composed by different not connected pieces. A workaround I found is to run the subdivision inside a “for each connected piece” for loop.
I uploaded the hip file in case anybody wants to test.
Cheers
Cheers
Edited by Andr1 - April 18, 2018 07:05:51
