I just tried the GoZ hda but without succes. Most likely because I'm using 2018. :-)
Is a 2018 version available or in the works?
Or could it be I'm just doing something wrong?
Rudi
I never make the same mistake twice. Always five or six times, just to be sure. :-)
GoZ to ZBrush 2018
4822 6 1- RudiNieuwenhuis
- 190 posts
- lkruel
- 240 posts
- RudiNieuwenhuis
- 190 posts
- lkruel
- 240 posts
- RudiNieuwenhuis
- 190 posts
It was the pighead i was trying to send. I was on 473 but i'll try the 496 now.
Will let you know.
Nope, no luck.
I noticed i had an old version of ZB installed still, but removed it so there is only 2018 left. Tried with 16.5.496 and the GOZ hda that i got from the dropbox just 5 minutes ago: https://www.dropbox.com/s/cibtavd9hm0686u/goz_installer16_5.hda?dl=0 [www.dropbox.com]
ZB does start, but it crashes instantly, before you can even see it tries to put anything on the canvas.
Needless to say ZB works fine, importing the pighead through a .obj that i saved from Houdini works as expected.
Will let you know.
Nope, no luck.
Edited by RudiNieuwenhuis - June 15, 2018 02:57:54
- kamasali
- 6 posts
- rodtaam
- 3 posts
