Is there a way to constrain cloth to a wire object and have mutual feedback?
The cloth attach constraint seems to work with RBD objects but the cloth solver errors if you try and constrain it to a wire object.. I can use a constraint network to constrain them together but there doesn't seem to be any feedback on the cloth from the wire.
I'm guessing since they are solved in different solvers you would have to fake the interaction somehow..
I've attached a test scene - one where I set up a constraint network and one where I took the example scene of constraining cloth to RBDs and tried to get it to work with a wire object (i'm guessing for that example scene there isn't actually any feedback on the RBDs from the cloth either..)
Constraining cloth to wires
835 0 0- Michael Battcock
- 30 posts
