OK, this one is driving me nuts.
Using Houdini Indie 16.5x and I'll be happily tumbling around the viewport using my mouse and spacebar, and then, for no apparent reason, when I try to rotate around the object, and I press the spacebar and then move the mouse left or right, the viewport zooms INTO the object and doesn't keep the same zoom level as I had.
This only happens IF I move the mouse over the object. If I move the cursor in an empty area, it works as expected.
I'm sure I've hit some combination of keys to get this ‘setting’ to work as it is. If I restart, all is good.
This seems to only happen when I'm inside a GEO node, if I am at OBJ level, it works as expected.
What am I doing wrong?
NOTE: This issue is only present when I have a camera selected and ‘locked’ so I'm moving the camera view around. If I just use the normal viewport, it doesn't exhibit this issue/feature.
Thanks,
Jim
Unwanted Viewport Zooming Into Object
1250 0 0- reelinspirations
- 177 posts
