I'm having a bit of trouble with the Terrain Mesh Rop, maybe someone can help me here.
With Adaptive density i get “holes” in my mesh. Where there is two faces from different resolution next to eachother, the smaller ones get detached from the bigger ones. This is best explained with an image:
Furthermore, exporting results in errors. I can only save the resulting geo manually, but the export button results in: OperationFailed: The attempted operation failed.
Error while cooking.
Could this be a H17 vs H16.5 issue? I'm using 17.0352
Rudi
Terrain Mesh Rop issues
3889 4 0- RudiNieuwenhuis
- 190 posts
- Ambrosiussen
- 197 posts
- RudiNieuwenhuis
- 190 posts
AmbrosiussenSorry, was away for a couple of days. This was in H17 with 1.64.
Could you tell me what version of the toolset you are using?
Paul
Rudi
Just tested with 1.66, same problem.
The problem seems to be in “attribwrangle23” where the NeedsTriangulation is set.
Prims that are adjacent to smaller prims (from a higher subdiv) do not necessarily have more then 4 primpoints so they don't get triangulated.
Hope this helps.
Update, tried in 16.5.571, works as expected, so it is a H17 only issue.
Edited by RudiNieuwenhuis - Oct. 30, 2018 10:17:08
- RobW
- 147 posts
Running into the similar issues here.
Just trying to walk myself through the workflow&nodes,but I cannot export a FBX mesh, or render textures for that matter.
Getting an error on FBX export:
hou.ObjNode of type geo at /obj/terrain_valley/sop_terrain_segment_rop1/OUT_GEO/TerrainExport/Segment_1, hou.ObjNode of type geo at /obj/terrain_valley/sop_terrain_segment_rop1/OUT_GEO/TerrainExport/Segment_2, hou.ObjNode of type geo at /obj/terrain_valley/sop_terrain_segment_rop1/OUT_GEO/TerrainExport/Segment_3, hou.ObjNode of type geo at /obj/terrain_valley/sop_terrain_segment_rop1/OUT_GEO/TerrainExport/Segment_4.
Edit: just realized I cannot export FBX in Apprentice….
And no error on texture baking, just the baking popup showing it is rendering something.
Houdini 17.0.381 (Apprentice) & GameTools v.1.72
Basic test:
Open Houdini, get a basic terrain from the shelf, add both the terrain_segment and terrain_texture node. Try toexport render some textures.
Edit: There seems to be a restriction on the renderable size of textures in Apprentice. Not sure what size I can render though…
Basic test:
Edited by RobW - Nov. 13, 2018 12:42:48
Apprentice Attribute / Houdini 17.0.381 / GTX 970 - driver 411.63
- Ambrosiussen
- 197 posts
RudiNieuwenhuisAmbrosiussenSorry, was away for a couple of days. This was in H17 with 1.64.
Paul
Rudi
Hope this helps.
I was able to reproduce the issue with Terrain Segment ROP and have submitted a fix.
It will be fixed in build 1.84 and newer.
Paul
Edited by Ambrosiussen - Nov. 21, 2018 16:44:14
