Error updating toolset
   2916   3   0
I'm getting an error when trying to install the game development toolset on houdini core 17.0.352
How to fix this?
thanks!
  File "update_toolset", line 116, in on_updatebtn_press
  File "update_toolset", line 295, in on_dialog_close
  File "update_toolset", line 325, in patch_houdini_env
IOError: [Errno 2] No such file or directory: 'C:/Users/yverde/Documents/houdini17.0\\houdini.env'
  File "update_toolset", line 121, in on_uninstallbtn_press
  File "update_toolset", line 301, in on_dialog_close
Hey yanverde,
Do you have $HOME or $HSITE set to something different than the default?
Looks like your Houdini preferences aren't being saved to the default location
Luiz Kruel
Senior Technical Artist
It's a brand new Houdini installation. I don't know what happened, but I just opened the command line tool to check that and without changing anything it worked.
Thanks for the fast reply!
Howdy,
I'm also getting errors, not on the installation, but on every launch afterwards. I've tried both the production build version of the tools and the latest one (1.82) and get similar errors. Houdini build is 17.0.407
Cheers
= = = = Viewer states registration = = = = Error: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/viewer_states/sidefx_bend.py Traceback (most recent call last): File "", line 1, in File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/python2.7libs\stateutils.py", line 563, in register_pystate hou.ui.registerViewerState( template ) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/python2.7libs\hou.py", line 56942, in registerViewerState return _hou.ui_registerViewerState(*args) NameConflict: Name conflict was detected. Error registering 'sidefx_bend': already registered. Error: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/viewer_states/sidefx_lop_edit.py Traceback (most recent call last): File "", line 1, in File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/python2.7libs\stateutils.py", line 563, in register_pystate hou.ui.registerViewerState( template ) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/python2.7libs\hou.py", line 56942, in registerViewerState return _hou.ui_registerViewerState(*args) NameConflict: Name conflict was detected. Error registering 'sidefx_lop_edit': already registered. Error: C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/viewer_states/sidefx_stroke.py Traceback (most recent call last): File "", line 1, in File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/python2.7libs\stateutils.py", line 563, in register_pystate hou.ui.registerViewerState( template ) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.407/houdini/python2.7libs\hou.py", line 56942, in registerViewerState return _hou.ui_registerViewerState(*args) NameConflict: Name conflict was detected. Error registering 'sidefx_stroke': already registered.
Edited by rafaels - Nov. 21, 2018 10:53:30
Toronto - ON
