i have two curve segments that i join into one, but whenever i change a size parameter,then point number around the curve changes and all normals get reversed.
In the attached image you can see an attribute delete no de before the join, everything works fine until there, no changes whatsoever. it breaks when the curves are joined.
Join node reverses normals
910 0 1- PhilipPappas
- 10 posts
