Hi!
I made the mistake of naming a variable "windowTypeCount“ when it should be named ”typeCount" instead. I've use this variable many times in the script so I would like to know if there's a “search and replace” tool to edit my VEX code.
-Olivier
VEX: how to replace variable/attribute name everywhere in your script
4403 6 0- olivierth
- 1013 posts
- bonsak
- 459 posts
- olivierth
- 1013 posts
- bonsak
- 459 posts
- tamte
- 8622 posts
olivierthif you open expression editor (Alt+E with the cursor in your code) you'll see search & replace function
or you can directly press Ctrl+H with the cursor over your VEX code
olivierthit's a HScript command, you need to run it in the Textport and point to your wrangle using arguments mentioned in the help
is it a function?… I'm lost.
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- olivierth
- 1013 posts
- OdFotan
- 192 posts
