Fluid Source / emit particle fluid help in R17
2964
2
2
- atracksler
- 41 posts
Going through a tutorial for Optical Flow:
At 19:17, an Emit Particle Fluid is added to the sim.
When I add it in R17, I dont see the fluid source (create_surface_volume) or the merge_surface_volume
Screenshot attached, my H is on the Left, tutorial on the right.
How woould I go about doing this in R17? Ive been pretty stumped….
Thanks so much in advance.
ad
Screen Shot 2018-12-30 at 10.58.12 AM.png (1.0 MB)
- cellos
- 4 posts
Hi mark,
I was doing your tutorial and I just got stuck in the same part, I don't know how to move forward. Have you found a solution?
Thanks,
Marcello
- silkey
- 13 posts
Hey Mark
I installed 16.5, put in some dummy geometry and ran the shelf tool. This I then copied and pasted into 17.5
I will try and work out the alternative method and post a hip but this is the quickest way.
Paul
