I am trying to copy a bunch of tubes to points on a surface to align with the normals direction but of course this is never easy and I think the most asked question on the forum.
As you can see in the attached image my point normals(blue ones) are all facing up. My primitive normals(pink ones) are facing as they should, in the direction of the face.
I have created a point in the center of each primitive face, that is what I want to use to copy the tubes to but the normals all face up and I get the typical undesired outcome. What I am interested in doing is somehow transferring the prim normals information to the point normals, is that possible? Is there another/better solution?
Transferring Normal Direction
3590 2 0- chanson78
- 45 posts
- Andr
- 900 posts
In the primitive wrangle when you create the points use this code:
it sets primitive normals to the new created point.
Of course you have first to create the primitive normals, otherwise there's no attribute to transfer: just add a normal node before the wrangle, and set it to primitive
removeprim(0, @primnum, 1); int newpt = addpoint(0,@P); setpointattrib(0, "N", newpt, @N, "set");
Edited by Andr - June 6, 2019 09:24:49
- Andr
- 900 posts
Andr
I just realize that this is unnecessary: normals are implicit for the primitives. So even if you don't see any ‘N’ attribute in the primitive spreadsheet, the above code would work anyway. You can skip this passage
Edited by Andr - June 6, 2019 09:24:32
