Modify Saving Frame Range
2312 2 0- chanson78
- 45 posts
- tamte
- 8599 posts
timeshift your geo after sim to your range (using $F-149)
you can also use Retime SOP for that
then cache frames 1-90
OR (little less obvious when debugging, but should work the same)
instead of naming the export name.$F.bgeo name it: name.`$F-149`.bgeo
or if you need padding: name.`padzero(4, $F-149)`.bgeo
Edited by tamte - June 12, 2019 10:03:09
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- chanson78
- 45 posts
