How to create UV on VDB converted polygon mesh
   7903   4   4
Hi guys,
I'm recently stucked into this problem… i can't really figure out a solution.
I'm trying to create UVs on an animated geometry, creted by a vdb convert node.
My setup is something like this.
- i create an animation with vellum hair (i need these hairs to be the source of my vdb polygon)
- vdb from particles on that hairs
- vdb convert into polygon
I atatched a jpg
Obviously, every frame the polycount change and also the UV. Results: the entire UV for the animated geo is a mess.
I guess i should create the uv on the hairs, or something like this, before the animation starts… am i right?
If someone could show me a solution i'll be really greatefull.
Thaks
uv problem.jpg (786.1 KB)
Moin,
without knowing more details about the scenario, it's probably hard to suggest “the solution”. However, I assume that the main problem is “sticking the UV to kind of the same places on the mesh” to avoid “flicker” or moving texture.
The general approach I would try to take is have “control points” on the original setup that you “track” over the range of the animation/simulation - e.g. by finding nearest points to re-establish the control points. Then recreate the UV based on those control points from a deformed “reference mesh” (or cage mesh) (maybe doing a from-camera-projection?).
On the same idea, if you are rendering for 2d (movie) anyway, you could actually get away with doing a frame-by-frame texture projection. That would break if you have to render for 3d.
Marc
Good bye.
Hey Dude,
I think there is no way u can create perfect uvs for this, but here is a cheat, u can create a grid with uvs and deform it along with the vellum wires and then transfer the uvs from the animated grid to the vdb mesh, I have attached a hip file, I Hope that might help.
Best,
Edited by Mohanpugaz - July 24, 2019 04:55:04
stickUV.hip (533.8 KB)
Mohan Pugaz
movfx
Hi Mohan
Thanks for the above solution though it didn't solve my problem but gave me another idea by which it got solved.
Hope u doing great! See u after pandemic
Cheers!!
AshwinFX
Hi Mohan
Cheers!!
Hi!
I'm having the same problem, how did you solve it?
Mage level 2
www.headofoliver.com
