Hello;
I can't find any option in Mantra, to skip (existing) rendered frames.
Is there any script or something like that to help?
Thanks.
Is there any option in Mantra, to skip (existing) rendered frames?
2285 4 1- Masoud
- 407 posts
- jsmack
- 7794 posts
- Anthony Morrelle
- 39 posts
- Masoud
- 407 posts
- harryabreu
- 76 posts
Hi Masoud.
If I understood correctly you want to skip some frames?
If I am right it simple, when you “turn on” RENDER FRAME RANGE you will see START - END -INC normally INC is set to 1 if you put it set to 2 and it will drop 1 frame like this 1-3-5-7 etc or you can put “1.5” it is not a kidding you can use float.
If it is not what you looking for sorry :-)
