Improving 8K textures close-up (Redshift)
   6447   5   1
I have rendered this simple scene with Redshift, using textures generated by processing 16K and 8K assets from NASA and https://www.solarsystemscope.com/textures/ [www.solarsystemscope.com].
I have attached three sampled screenshots from the resulting 10000x10000 rendering, which looks terrible for some reason. The textures are in PNG format, and I have attached a sample of the flat texture I used for the lunar surface.
Is there a way to improve the definition of the texture, maybe with a filter? Does RS have any specific filter that might help?
Fabio Basile - 3D Artist
https://www.behance.net/fabiobasile [www.behance.net]
the “broken” images don't look like they are showing a problem that a filter could fix, instead, they look like a stripe-offset-error in reading/displaying the actual data. It might be coming from your UVs (could, maybe, be a floating-point issue?) or could be a bug in RS.
Have you tried narrowing down if the error appears on a simplified model (like a plain grid)? If it also appears there, have you tried exposing the issue in the Red Shift community?
Marc
Good bye.
They look like floating point arithmetic errors. Is your “moon” really big?
You may be onto something, and this makes total sense. I suspect that this may very well be a RS issue, as all my textures, no matter what mesh I use, present similar problems.
I have initially created the scene to reflect roughly accurate distances between the Sun, Moon and Earth, as well as their relative size, scaled down to by quite a few decimals to make it manageable, but not so small as to have the moon down to 0.0000~e scale. Still, proportionally, the distance between the sun and earth/moon is about 1 kilometer, and i have placed an RS point light inside the Sun, and have specified only the moon and earth in the list of objects influenced by the light source. I have also a light dome, which does not affect anything, as i have turned it off, and only used it to have a spherical projection of the stars, which I have generated from NASA footage, and down-sampled it to a 2Kx4K.
All meshes are textured using UDIM tiles, however the issue manifested even with regular textures.
I have eliminated all the volumes, dome light, and rendered each mesh individually, and I also tested it with sample objects, and the issue still persists.
I will bring this issue to the attention of the RS community as well, hopefully I'll get to the bottom of it, but thanks for pointing me in a good direction, very much appreciated! :-)
Here's a happy update:
According to a response i got in the RS community forums, a working fix is to go into the experimental section of the Redshift ROP, under System, and check “Render In Camera Space”. I have tested it an apparently the issue is gone.
Ah, “render in camera space” sounds like they are then first applying the camera matrix to the world space construction before projecting textures - that would get around massive floating-point issues that you would have with such huge scales (assuming you are using meters / SI units in the scene).
It *might* help to use a scene dependent unit like “diameter of the sun” instead of something like meter or kilometer. However, I fear that with the differences in sizes and distances in a solar system, ANY “fixed” system will run into limitations if you want to apply really fine detailed textures - I haven't looked at your source data, but I assume you are using meter/kilometer sized pixels there and are trying to project those onto immense areas. That's always going to be a problem, don't even think about SIMULATIONS with specifically tailored solvers for such setups :-D
Marc
Good bye.
